starts and won't keep running, found fuel filter compleetly plugged thought this was the problem. fuel pressure appears to be fine, fuel regulator is working correctly. If you add fuel with carb cleaner through a vacuum port the engine will keep running. No change if you unplug the mass air flow sensor. I cleared the codes and now it has a mass air flow code, however I believe this was from unplugging the sensor. Any ideas?
Aug 23, 2009 at 10:13 PM
