1983 Volkswagen Beetle Carburetor dripps gas after shut dow
1983 VOLKSWAGEN BEETLE
10,000 MILES • 4 CYL • 2WD • MANUAL
DE-BUG-GER
Hello, I just bought a 1600cc 83 vw bug. it did not run and as part of reparations I put a set of new carburetor gaskets and needle valves. now it runs well but after shutting down engine, carburetor would start dripping gas to both intake manifold and engine crankcase. I did already double check floater's needle valve, they are ok! can you give me an idea of what going on??
thank you in advance!
Feb 26, 2008 at 9:35 PM
Did you adjust the fuel level/drop-you sure the float is not sinking with a pin hole on it.
Feb 26, 2008 at 10:06 PM
