1973 Volkswagen Beetle Engine Code
1973 VOLKSWAGEN BEETLE
BILLSIGLER
  • 4 POSTS
Engine Mechanical problem
1973 Volkswagen Beetle Automatic
Have a Trike built with a VW engine and it has no engine code below the generator stand on the block. How can i tell which engine is in my trike. I need this info when purchasing parts. THANKS
Jun 3, 2009 at 5:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I would say that you have an industrial version, as all automotive engines will have the engine code stamped on the engine case, i feel it will be a 1600, can you tell me how many notches on the pulley for timing the engine?this may be a clue.
mark (mhpautos)
Jun 4, 2009 at 5:22 AM
BILLSIGLER
  • 4 POSTS
has one mark on pulley.....bottom right of engine case reads 2BR BRAZIL....thanks
Jun 4, 2009 at 7:31 AM
MHPAUTOS
  • 31,937 POSTS
Hi there, I will see what i can dig up.
Mark (mhpautos)
Jun 4, 2009 at 5:02 PM
BILLSIGLER
  • 4 POSTS
Thanks, will be looking forward to your help
Jun 4, 2009 at 10:38 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
I spoke to a few VW people and they feel its a twin port 1600, most externals are the same but if you are doing a re build just measure the bores for the correct engine size, no one has cone across that I.D. so it is a bit of a mystery.
Mark (mhpautos)
Jun 5, 2009 at 12:15 AM
BILLSIGLER
  • 4 POSTS
Thanks for the help...any other info you can pass along will be helpful
Jun 6, 2009 at 4:13 AM
JALOPYPAPA
  • 467 POSTS
Maybe this will at least give you what the range of numbers for the original case would have been:
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Jun 11, 2009 at 11:37 AM
