1970 Volkswagen Beetle Tune up
1970 VOLKSWAGEN BEETLE
CFULLA
Engine Mechanical problem
1970 Volkswagen Beetle 4 cyl Two Wheel Drive Manual Many miles
What do I need to tune up my 1970 VW bug and how do I go about doing it?
Sep 12, 2009 at 10:16 AM
JALOPYPAPA
  • 467 POSTS
1. Change the contact points and condenser. Take off the distributor cap, pull off the rotor and unscrew the contact points. Adjust them to the proper gap when the cam lobe is pushing against the cam rider. I forget what it is; I want to say it's about .020.
2. Set timing to about 5 degrees before TDC. This requires a static or strobe timing light and a wrench to turn the crankshaft.
3. Replace spark plugs.
4. (optional) set valve lash.
Oct 4, 2009 at 3:20 PM
