1968 Volkswagen Beetle starter switch
1968 VOLKSWAGEN BEETLE
CMAUPIN
Electrical problem
1968 Volkswagen Beetle 4 cyl Two Wheel Drive Manual
1968 VW Bug. When i try to fire up the bug it starts for a second and when i release the key it dies..like there is no juice going to the coil after the key is released. I had the starter switch replaced a few months ago and the problem was solved. Now I am having the same issue again. I have only driven the bug twice inbetween the visit to the mechanic and now. What could the issue be?
Oct 21, 2008 at 3:20 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
you can easily check the power to the coil with a test light, there should be constant battery voltage at the Pos terminal with the ignition on, start here.
Mark (mhpautos)
Oct 21, 2008 at 4:40 PM
