1965 Volkswagen Beetle Light tan substance in oil filler ca
1965 VOLKSWAGEN BEETLE
M164285
Engine Cooling problem
1965 Volkswagen Beetle 6 cyl Two Wheel Drive Manual
I have found a light colored substance in the oil filler cap of my 1965 VW 1600. I believe it is caused by condensation. What can I do about this and is there anything I can do about this?
Mar 30, 2009 at 12:58 PM
BLACKOP555
  • 10,386 POSTS
when was last time oil changed?
you might have damage on your seals. excessive water in gas or a bad headgasket.
also be a crack in a line. bad grommets for pcv valve and breather valve.
or just simply from heating and cooling of the engine.
Mar 30, 2009 at 8:18 PM
