I watched your video regarding pulling a vacuum and charging. I noticed the technician used the vacuum line and the low side only not opening and or connecting the high side?
My vehicles A/C always got warmer after a couple of years and decided to tackle the issue. Simple enough, the Shrader were leaking. After hopefully matching the valves i decided to change the dryer as well. This dryer came with new gaskets less the gasket connected to the electrical connection, so I used the old one. Pulling a vacuum yellow and the low side I have a bad leak. I ordered new gaskets and need to find the leak. Is the new dryer need replacing again. Since it's been exposed? Also need to find this huge leak and it must be related to the new dryer.
Thanks so much
Thanks so much
Sep 8, 2024 at 9:03 AM
