Vibration when car is in park
1997 CHEVROLET LUMINA
120,000 MILES • 3.1L • V6 • 4WD • AUTOMATIC
RKRELL1021
  • 5 POSTS
My car shakes when in park.
The engine mount was replaced a few weeks ago and I had a alignment several months ago.
Thank you,
R
Jun 13, 2021 at 6:17 PM
Good morning,
There are a total of 4 mounts for the powertrain. I posted the mounts below for your review.
https://www.2carpros.com/articles/how-a-motor-mount-works
https://www.2carpros.com/articles/replace-motor-mounts
Which mount did they replace? The upper engine struts were the most common failures for the big movement of the engine while running.
https://www.2carpros.com/articles/vibration-noise
Are you sure it is a mount issue and not the engine running rough making you think it is a mount?
https://www.2carpros.com/articles/engine-misfires-or-runs-rough
Jun 14, 2021 at 3:51 AM
RKRELL1021
  • 5 POSTS
Thank you for the info.
I will check my paperwork from the mechanic.
Thank you,
Rochelle
Jun 14, 2021 at 9:24 AM
Let me know what it says.
You are welcome.
Always glad to help.
Jun 14, 2021 at 9:37 AM
RKRELL1021
  • 5 POSTS
Hi Roy,
They replaced the lower engine mount.
Thank you,
Rochelle
Jun 18, 2021 at 8:36 AM
Did that fix it?
Jun 18, 2021 at 9:04 AM
RKRELL1021
  • 5 POSTS
Hi Roy,
No, it still shakes.
Thank you,
Rochelle
Jun 18, 2021 at 1:57 PM
The other mounts I listed need to be checked for being broken or worn out.
Jun 18, 2021 at 2:31 PM
RKRELL1021
  • 5 POSTS
Hi Roy,
I was advised that the other mounts were checked and were okay.
But they put an aftermarket part when they replaced the lower engine mount that was worn.
I think putting an aftermarket part instead of the original part would make a difference.
What is your opinion?
Rochelle
Jun 20, 2021 at 11:32 AM
That is correct. The aftermarkets one are not the same. That is why they are double the price.
I think one or more of the others are worn as well. Ask them to recheck them.
Jun 20, 2021 at 12:19 PM
