Slight right-left steering movement. vibration completely disappears when accelerator is released. with/without awd fuse. new front bearings, half shafts, ball joints,engine runs smooth, shifts smooth, new rotors/brakes, struts. nothing has fixed it. does it without the tires too. (brake rotors removed appears to be coming from the transmission itself while turning drive-line on rack. there is nearly 10-15 degrees of rotational play on each front tire while hand rotating.
May 24, 2020 at 6:30 PM
