Recently after 3 to 4 minutes of highway driving (55- 75 MPH) there is a rough vibration when on the gas maintaining speed, almost as if the RPMs are dropping too low. The vibration goes away completely when letting off the gas, and there is no vibration under normal/heavy acceleration. There doesn't seem to be any specific noise associated with the vibration and the vibration is constant when it occurs. I'm unsure if the vibration occurs at lower speeds, if so, it is very subtle. No warning lights, no smells, no smoke, no visible fluid leaks.
Some things to keep in mind: New factory short block installed at 86,000miles, CVT fluid was last changed during that time (≈20,000miles ago) Recently had a brake service done (new pads/rotors) and all wheels are tight and torqued.
Apr 30, 2024 at 6:33 AM
