Vibration of engine at lower speeds
2005 BMW 325I
190,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
LAURAS325I
When driving at speeds lower than thirty five mph engine vibrates. Computer indicated problem with valve number six.
Spark plugs and coil replaced. Problem continues. Plus, now I am getting hot air coming in at floor level. Maybe a hose got lose.
Aug 1, 2017 at 7:41 AM
It sounds like you have low compression in cylinder number six. I would remove the plug and then flow this guide to get the job done. If you do not have a gauge you can rent one.
Aug 2, 2017 at 3:14 PM
