Vibration in gear with brake on, not motor mounts
1997 FORD THUNDERBIRD
125,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
KENT THORNELL
  • 12 POSTS
The vibration is only when in gear (forward or reverse) and varies when steering wheel is turned. it gets worse as I turn the wheel then eases off (a little but always there) until wheel is turned again. I feel no movement of the drive train as I shift gears. The motor is rock steady with no lift or tilt when put in gear. I have checked motor mounts they are fine. I jacked up the driver's side once (both wheels off the ground a few inches) to do some other work and noticed that the vibration was hardly there at all while the car was raised at that angle. Could it be the transmission mount? If so, how do I check it? Any other advice? Thanks in advance.
Mar 22, 2019 at 2:06 PM
CARADIODOC
  • 34,306 POSTS
The solid engine when shifting gears is a clue. If the engine doesn't rock, it is not being held up by the rubber isolators. The best suspect is the rubber is deteriorated and the two metal parts of a mount are contacting each other. That will shake the entire car and be quite miserable. One potential clue to a collapsed engine mount can be seen where the radiator fan blade is not centered in the shroud. If there's a big gap on top, or the blade is off-center within the shroud, recheck the engine mounts.
The transmission mount is usually a "captive" design where the rubber isolator can't fall out, but if it is deteriorated, it can let the tail housing of the transmission sag. Sometimes you can lift that tail housing by hand and see the movement. Sometimes you can see the mount just doesn't look right. With a sagged tail housing, look for the drive shaft laying on an exhaust pipe or parking brake cable and transmitting engine vibration through those into the body. Even the shifter linkage, from the days before they went to a cable, have pivoting shafts that sit inside rubber or plastic bushings. Look for one of those that has cracked away, or a shaft is rubbing on the metal bracket. Rust can cause that too even when the engine mounts are fine.
Also look for a broken exhaust hanger, especially one that has a rubber isolator between the two metal parts. A broken hanger that is cobbled with wound-up wire tends to not result in this type of vibration, but a metal hanger sitting on the other half of the hanger will transmit normal engine vibration into the body where you will definitely feel it.
A less-common cause of vibration is sagged springs. Those can be expected due to the car's age. Every repair shop has a small book that lists every car model and year, where to take the measurements, and what they should be. Besides all the other problems sagged springs cause, that will change the angle of the drive shaft where it exits the transmission and where it attaches to the rear axle. That reduced angle is a common source of vibration when the car is moving, especially at higher speeds. When the vibration occurs when standing still, like you described, look instead for something the drive shaft is rubbing on. That's almost always a parking brake cable that runs right over the drive shaft, just behind the transmission. That has to be up high enough to clear the drive shaft when the car is heavily-loaded or goes over bumps in the road, so when you find this, you'll find a "witness mark" in the form of a rub mark around the drive shaft, and the cause is often a rusted attaching hanger for the cable. You'd find a clue by getting the vibration to occur, then observing it goes away when lifting on the rear of the car a little.
I've also had cars that had a metal strap welded to the end of the tail pipe to form a hanger. It has a 90 degree bend in it, then the strap slides through a rubber isolator that is held in the bracket that's bolted to the body. On one occasion the tail pipe was loose in the muffler, and it slide back, then that strap came out of the isolator and the pipe dropped down onto the rear axle housing. That caused more high-pitched buzzing noise and less vibration. On another car, that rubber isolator squirted out, then the strap fell down the 1/2" and sat on the metal bracket. That one didn't make any noise, but there was a horrendous vibration felt only when idling.
Everything up to this point refers to a normal engine vibration that you aren't supposed to be able to feel. Whatever is wrong is letting those vibrations transmit into the passenger compartment. Also consider the defect could be causing an abnormal vibration that at times you are unable to feel. The best example I can think of, although a poor one, would be a single-cylinder misfire due to a fouled spark plug or bad plug wire. You can feel that because the rotational speed of the crankshaft slows down when that misfire occurs. That becomes much harder to feel when you raise engine speed. This would be a case of feeling the vibration at idle is the normal condition, as far as diagnosing it goes, and raising engine speed is what you'd want to avoid during the diagnosis step since it makes the problem go away. In the first half of the story, we're diagnosing a normal vibration that you aren't supposed to feel. In this second part, there's an abnormal vibration that can't always be felt. For those, here's a link to an article that refers to those things:
https://www.2carpros.com/articles/vibration-noise
Mar 22, 2019 at 11:24 PM
KENT THORNELL
  • 12 POSTS
Thank you so much for educating me on this subject. I always thought that an engine tilting wildly meant bad mounts, not one that did not move. I am sure that is the problem. the 4.6l does not have a fan (it has an electric) and the engine runs fine with no misfires. Now if I can just figure out how to replace the mounts. It looks very cramped and no easy to get to them.
Apr 1, 2019 at 6:41 AM
CARADIODOC
  • 34,306 POSTS
You might consider asking a busy mechanic to step outside for just a minute to watch your engine while you shift between "drive" and "reverse". He should be able to say right away if the amount of rocking looks appropriate.
Years ago engine mounts were basically two flat pieces of metal with a rubber block sandwiched in between. Due to the direction of engine rotation, it wants to lift up on the driver's side under hard acceleration. That would tug repeatedly on that mount and eventually tear the rubber apart. It was not uncommon, especially on Ford products with the larger V-8 engines to see an outward dent in the hood from being hit by the air filter housing.
The first improvement was to add a wing to each metal part of the mount. Those overlapped but were about an inch apart, until the rubber broke, then those wings would hit each other and prevent the engine from lifting up. The latest designs used on most cars since the late '80s uses a round piece of rubber inside part of the mounting bracket, and a bolt goes through the center of it. If the rubber breaks, all that can happen is that side of the engine might drop down a little, and it can raise up a little higher than normal when accelerating. We call those a "collapsed" engine mount instead of a "broken" mount.
Apr 1, 2019 at 6:15 PM
