Vibration at idle and when reversing.
2003 VOLKSWAGEN PASSAT
160,000 MILES • 2.8L • V6 • AUTOMATIC
SHAHRANA
car vibrates when its idle. Its worse when reversing. vibration goes away as soon as i press accelerator.
Feb 20, 2014 at 3:33 AM
Is the idle speed properly set? Have you checked for vacuum leaks on the engine? When was the last tune up?
Feb 20, 2014 at 8:34 AM
SHAHRANA
I had the car serviced two weeks ago. the mechanic there told me that it could be because of the pressure regulating valve leaking. i am not sure about the idle speed.
Feb 21, 2014 at 7:49 AM
Is he referring to the fuel pressure regulator? If so, that can cause it.
Feb 26, 2014 at 4:58 AM
