Vibration
2005 DODGE MAGNUM
100,000 MILES
TREYB
I have a 2005 Dodge Magnum SXT, and it makes a vibration(feels like it directly under the car) and it does it when i get up to 45 or 50 but while its doing the vibration, if i get my foot off the gas pedal it would stop as soon as i release the gas pedal. i really want to know what this vibration is coming from its so annoying, would you happen to have any idea?
Apr 26, 2013 at 9:08 AM
CARADIODOC
  • 34,306 POSTS
The two most likely suspects are a worn or tight universal joint and a deteriorated center support bearing for the drive shaft. Look around the u-joint bearing cups for signs of a reddish powder. If you see that, the joint needs to be replaced.
May 1, 2013 at 11:06 PM
