vibration
2005 NISSAN PATHFINDER
118,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
MIKE BOC
My vehicle started vibrating when accelerating between 50 and 60 mph. Once it gets above 60 mph it is fine, and no problem before 50. I recently had four tires and alignment just over 3,000 miles ago.
May 24, 2016 at 12:01 AM
HMAC300
  • 48,601 POSTS
check the drive-shaft u-joints they may be going bad. if you see rust around the seals of u-joint then it is pretty well gone.
May 24, 2016 at 6:10 AM
