vibration in steering when driving
2007 TOYOTA CAMRY
57,000 MILES • 4 CYL • AUTOMATIC
LAMMY86
When i drive as fast as 100 km/h my steering vibrates seriously. I have done the balancing, changed the tie rod, ball joint, lower arm bushing yet the vibration is not going away. Any suggestions?
Dec 23, 2016 at 1:08 PM
CARADIODOC
  • 34,306 POSTS
A better suspect is a broken belt in a tire. Switch them between front and rear. If the vibration changes to where you feel it in the seat, one of the tires on the rear has a broken belt.
Also consider there can be a chunk of rust or scale stuck behind a front brake rotor or between a rotor and wheel. That will cause that wheel to wobble. That will not show up on a wheel balancer.
Dec 23, 2016 at 1:17 PM
LAMMY86
I will look into that. Thanks
Dec 23, 2016 at 1:26 PM
Hey LAMMY86,
Also check the front CV joint, remove the axles and check the rotation of the joint for hard spots.
rotate the tires front to back as well.
Here is a guide to help you fox the problem.
https://www.2carpros.com/articles/replace-cv-axle
Please let us know what you find so it will help others.
Best, Ken
Dec 28, 2016 at 12:27 PM
