vibration when accelerating?
2005 CHRYSLER PT CRUISER
272,700 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DNARVAEZ
This starting happening a few hours ago. On my way home from work, I was at a stop light, then I turned to have the car some gas and start to feel tons of vibration. It keeps happening but i feel it the most when I give the car gas. What is the problem?
Sep 20, 2019 at 5:06 PM
You are saying that the vehicle is vibrating all the time even at idle not moving? Most than likely this is a misfire or a vacuum leak. Do you have a check engine light?
Give these two guides a read and let me know what you think. If something sounds like your issue, let me know and we can dig further into the solution.
https://www.2carpros.com/articles/engine-vibration-at-idle
Sep 20, 2019 at 6:53 PM
Good afternoon,
This sounds like a CV joint in one of the axles is failing. When there is pay in the joint, it will give a vibration on acceleration.
I attached the procedure for replacing the axle shafts below along with some guides.
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/replace-cv-axle
Jul 28, 2021 at 3:26 PM
