Vibrating when turning
2013 HYUNDAI GENESIS
84,800 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
CASPEE
Every time I am turning the steering wheel there is a loud noise like something is either dragging against, maybe something is broken or misplace. And the car also vibrates when turning the steering wheel.
Sep 17, 2019 at 1:22 PM
Do you think this noise would be heard on a recording? Definitely, sounds like something is rubbing but hearing the noise may make the cause jump out to me.
If not, then we will need to inspect under the vehicle while someone else is turning the wheel. Clearly not while it is moving but the engine is running so that you can turn the wheel.
Let me know about the video of the noise and we can go from there. Thanks
Sep 17, 2019 at 6:42 PM
CASPEE
Don’t have a video right now but the noise is the vibration. Just like you said, something might be rubbing or stuck. If this doesn’t help I will send a video later.
Sep 17, 2019 at 7:22 PM
Okay. Unfortunately, I won't be able to tell you what it is. Hearing it may help but I can tell you how to try to figure it out.
Have someone else drive the vehicle and you stand next to the vehicle. Have them turn the wheel and drive slow and you walk next to the vehicle and listen for the noise. It will be much quieter because your speed is slow but if something is dragging you should still hear it. Do this on both sides to see which side is louder. Then lay on the ground and look around the wheel and then up under the vehicle when they are turning the wheel back and forth full travel left and right. While looking under the vehicle watch all the components that are turning to see if anything is making contact with each other. Nothing should be touching.
If you can get the video I may be able to narrow this down for you because things in this area make distinct sounds.
Sep 17, 2019 at 7:52 PM
