Hi Justin, have you scanned the computer to see which cylinder or cylinders are misfiring? That is where we should start.
A misfire can be caused by a few different things. For example, the vehicle may be in need of a tune up or a coil pack may be failing. Once we determine which cylinder is causing the problem, we can target that cylinder to determine the cause.
Let me know if you have already retrieved the codes and what they are. If you haven't, most parts stores will do it free of charge.
Jan 29, 2023 at 8:38 PM
