I had a blowout on the right front. Had tire replaced but tends to pull to the right. Had the upper idle arms changed could it be a motor mount?
Aug 23, 2023 at 12:36 PM
CERTIFIED EXPERT
An engine mount should not cause a pulling, I would check the remainder of the tires for the vibration issues because you may have tire treads that are separating. These guides can help:
