Very rough vibration at idle. Engine does not miss and stays steady at 800 rpm, but engine vibration is shaking entire car. Runs well at speed, pulls strong, no misfires or bogging under load. Oil looks good. Fuel pressure is good at 35-38 psi at idle. Used multiple bottles of fuel system cleaner to date. Cleaned MAF. Recently replaced downstream O2 sensor, plugs, wires, coil pack. Replaced crank position sensor six months ago. Replaced all motor mounts twelve months ago. Not sure what to do next: check compression, replace injectors, replace fuel pressure regulator, replace MAF, check for vacuum leak (how)? I do not want to throw money at random parts.
Car starts right up, pulls strong. Getting twenty four mpg (which is lower than it should be).
Jan 27, 2017 at 5:31 PM
