No heat, vents blow cold air
2006 PONTIAC G6
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
AUNTJJ2
I have flushed heater core, checked actuator, checked coolant, bled air out of system, checked thermostat, checked all hoses. I had just warm air after flushing and then drove car for a mile and heat quit blowing only cold air from vents. The temperature stays at a constant 210 when sitting running or driving, the blower works, no clicking noises. The vents in the center seem cooler and the is a little warm air that comes out on the floor when driving but no other heat. What else can I check?
Nov 9, 2018 at 7:42 AM
Good afternoon.
From all you have done and checked, I feel you have a bad heater core. There may not be enough circulation to give you the proper amount of heat.
https://www.2carpros.com/articles/replace-heater-core
https://www.2carpros.com/articles/car-heater-not-working
Nov 9, 2018 at 9:37 AM
