I attached the testing that we need to run through. It is not the easiest but that would explain why the lights come on just after moving a little while. This is basically saying that the speed sensor is not registering.
Many people just replace the speed sensor and see if that fixes it. Sometimes it does and others it doesn't. I would recommend running through this and seeing what we come up with because it could be just as likely an ECM or harness.
Let me know if you have questions. Thanks
Sep 14, 2020 at 6:33 PM
