After replacing the fuel pump and filter I cannot put but about $8.00 in fuel in the tank before it auto shuts off and you have to lightly squeeze to get fuel in. Ran code reader after a check engine light and have code po443 evap emissions system purge control valve circuit.
Replace the evap pressure sensor above the tank.
Replaced the solenoid over the right rear axle.
Replaced the gas cap.
Replaced purge valve.
And the code still remains and cannot put fuel in the vehicle.
Jul 7, 2022 at 6:41 PM
