My truck runs great transmission shifts smoothly, but once i get exactly at 45 MPH i feel a bit of a vibration on my pedal and floor. Then it stops if i accelerate more and then when I'm on the freeway i feel it even more and a bit of steering wheel vibration as well as a slight humming sound. I already changed my wheel bearing because i checked it and it did have some play on the passenger side also under the truck i did see that the rubber from my carrier bearing was a bit torn so i replaced that as well. All with Toyota parts from the dealership. I also checked the u-joints and those are in great shape. But the problem still continues. Then I did wheel balancing and tire rotation, and the same thing happened. I did notice that my truck does tend to go to the right side when I'm driving. So, i do now know i need an alignment. Could it be something to do with the suspension or alignment that is causing this weird vibration?
Jul 22, 2022 at 7:31 PM
