I followed your demonstration of checking the COP circuit. When the ignition is in the on position, the coil sockets have the equivalent of the full battery power, approximately 13 volts.
The car starts normally and then dies after a few seconds. The OBD code is 12, meaning no error is detected. Please confirm that the voltage when ignition is on (without cranking should be zero). Then where is the voltage coming from. it would have to come from the ignition switch.
Sep 18, 2019 at 8:17 AM
