Vehicle speed sensor on transmission pinout diagram needed?
1998 FORD RANGER
218,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
XSALUTE417X
The previous owner cut out the pigtail to the VSS on the transmission and the speedometer is inaccurate. I’m looking for a pinout diagram or a wiring diagram so that I can rewire it from where it’s getting power and ground to fix the speedometer issue.
Sep 7, 2025 at 4:09 PM
CANNON1349
  • 861 POSTS
I have attached some diagrams as well as the input and output lines for the VSS on the transmission. I hope this helps. Please let us know how it turns out.
William
Sep 7, 2025 at 4:56 PM
XSALUTE417X
I believe that’s for a 4.0, the speed sensor isn’t in the same place as mine. Mine is closer to the drive shaft and also only 4 out of the 6 images loaded.
Sep 8, 2025 at 9:27 AM
CANNON1349
  • 861 POSTS
Hello, yes the diagram does mention a 4.0L option, however the wiring is correct for the 3.0L. Sorry about the photos, we were having site issues. I attached the input/output lines for the speed sensor below. Hope this helps!
William
Sep 8, 2025 at 11:40 AM
