The speed sensor is on the transmission near the passenger side axle shaft output. Here is a diagram with red arrows showing its location Please let us know what happens. (BELOW) The input sensor is behind the side cover of the transmission. Attached below are the instructions and diagrams of how to replace it. Let us know if you need anything else.
1 - Pressure Control (PC) Solenoid Valve
2 - 1-2 Shift Solenoid (SS) Valve
3 - Automatic Transmission Input Shaft Speed (ISS) Sensor
4 - 2-3 Shift Solenoid (SS) Valve
5 - Automatic Transmission Internal Mode Switch (IMS)
6 - Vehicle Speed Sensor (VSS)
7 - Automatic Transmission Fluid Pressure (TFP) Manual Valve Position Switch
8 - Automatic Transmission Fluid Temperature (TFT)Sensor
9 - Torque Converter Clutch (TCC) Solenoid Valve
Apr 10, 2016 at 3:39 PM
