vehicle speed sensor
1998 VOLVO S70
163 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
ENG AHMED
i am having a problem with my Volvo when put the gear to R and park my car then turn it off. Come next day start it the speedometer work only for a couple of minute and then shut off. This situation repeats every day.
Can you help me?
Thanks a lot.
Mar 22, 2018 at 2:10 PM
MHPAUTOS
  • 31,937 POSTS
I would be thinking that the speed sensor is faulty, you can try cleaning the terminals of the plug with an electrical terminal cleaner, you can get this at any parts store, if that does not help i would consider replacing the sensor.
Mar 22, 2018 at 4:56 PM
ENG AHMED
I all ready changed the sensor with no help.
Mar 22, 2018 at 6:56 PM
MHPAUTOS
  • 31,937 POSTS
May be a cluster or wiring problem, a cracked circuit board or a dry solder joint may be a problem.
Mar 22, 2018 at 8:46 PM
Lets run the codes to see what comes up to start.
Please run this test and get back to us.
Mar 23, 2018 at 9:54 AM
