Vehicle starts to stutter at forty eight mph and goes on up . Religiously starts at forty eight. ODM code shows a misfire on number five cylinder.
Here are the maintenance activities from earliest to latest:
Removed catalytic converters and replaced with test pipes.
Replaced gas tank, fuel pump, fuel filter and spider modification fuel rail.
Replaced rotor cap, fist cap, wires and plugs.
Replaced TPS sensor.
Tany shop validates torque converter on newly rebuilt transmission.
Valves adjusted. Timing checked with diagnostics.
Fuel pressure is 58 psi.
No other codes except misfire on number five cylinder.
Spark plugs removed, threads cleaned and replaced.
PS.
When torque converter is taken out with diagnostic tool, problem goes away. All work performed by dealership and OEM parts.
Dean
803, 493, 2508
PS.
Dean
803, 493, 2508
Mar 26, 2018 at 2:09 PM
