Vehicle power failure
2008 OPEL CORSA
234,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
JAF39
My vehicle does not have power it idle, but if i put it in gear then it is reduced power. it make almost like the engine suffocate and backfire.
Mar 2, 2019 at 2:53 AM
There are only a few things that can cause a backfire. Take a look through this link and see if it helps.
https://www.2carpros.com/articles/engine-backfires-while-running
If the check engine light is staying on while the engine runs, you really need to have the computer scanned to determine what diagnostic trouble codes are stored in the system. Here is a quick video showing how it is done:
https://youtu.be/b2IJGfImVvw
I realize most people don't own a scanner, but often times parts stores will scan it for free. However, I'm not sure where you are located.
Mar 2, 2019 at 6:10 PM
