Vehicle not starting
1994 NISSAN SERENA
150,000 MILES • 2.0L • 4 CYL • AUTOMATIC
KITENGE
Hello.
I have a Nissan Serena. This car has failed on me at the gas station when I was refilling the fuel. It was driving fine, and when I switched it off, it did restart, but couldn't rev past 2000 rpm.
I scanned it and it gave the code of Mass air flow meter which I changed with another one and it didn't change a thing.
I then left and tried it the next day, there was no code, and the vehicle only cranked, but this time the car wouldn't start.
*I then checked and lifted the whole injector rail, and cranked, and all injectors sprayed on their on time.
*I checked the spark plugs, and it plug sparked and that proves the coils and spark plugs are fine.
*I redid the timing marks as well
*The fuel pressure is good, and I even changed the fuel filter and pump.
All the above has been done, and the vehicle still can't start.
Please advise
Aug 18, 2019 at 1:39 PM
MASTERWRENCH
  • 258 POSTS
Welcome to 2CarPros!
It sounds like you've covered all the basics. I know you've replaced the fuel filter and fuel pump. Any chance you pulled a fuel sample and closely examined it? It seems very coincidental that the engine ran fine until you filled it with a new batch of fuel. I would try starting it with an auxiliary fuel source such as starting fluid. If you can get it to start by doing that, there's a very good chance the "fresh" fuel you purchased is no good.
Sep 8, 2019 at 10:27 PM
