The vehicle will not start. We have gotten a new battery as it was no good any longer. I think it is something with the fuel pump or possible water in gas. The car will crank but does not start. I checked the fuel pressure and when I push on the valve pressure is released but no gas comes out. The car gas gauge says it is a little under a half a tank if that needs to be known. I also checked the fuel pump fuse and it was fine but replaced it anyway. Is there a way to tell if it is just water in my gas or if something else is wrong?
Jan 5, 2018 at 12:23 PM
