Good afternoon, my vehicle is overcharging.Do you know what can cause this to happen?Thank you in advance.
Jun 28, 2020 at 10:07 AM
CERTIFIED EXPERT
When you say it is overcharging, what is the actual voltage it is charging when the engine is running?
Take a look at this information. The ECM will target 14-15 volts and will back it down to 13.6 volts when needed. Let's start with what the voltage is and go from there. Thanks
Image (Click to enlarge)
Jun 28, 2020 at 4:49 PM
AUSTINO
MEMBER
Thank you for that information. yes, it is over charging when the engine is running and also the acid from the battery is leaking out.
Jun 29, 2020 at 7:20 AM
CERTIFIED EXPERT
Okay. Clearly we need to replace the battery but again, we need to find out the exact voltage it is charging. There is a chance that the PCM is trying to raise the voltage due to the battery so I would replace the battery due to the leaking and retest the alternator output.
