Vehicle Dies While Coming to a Stop or while Starting to move forward/reverse
2004 FORD EXCURSION
200,000 MILES
CHARLESWATSON42020
I have an automatic 2004 Ford Excursion 4WD and with a Triton V10. I am getting a code that says the "output sensor circuit malfunction".
Let me describe the problem in detail:
While driving the Overdrive Light on the shifter starts to flash and at this point if you slow the vehicle down too much it dies (kind of like letting off the clutch to much on a manual vehicle) It will start right back up but as soon as you engage the transmission you have to basically floor the gas pedal so that it will not die on you. It does this in reverse and in drive, however in park it idles fine. This problem happens more frequently and much quicker if we are pulling a trailer.
Is it just the Output Speed Sensor or the Output Speed Shaft Sensor or both or something else? Please help!
May 27, 2013 at 3:17 PM
CJ MEDEVAC
  • 11,004 POSTS
THIS MIGHT BE YOUR SITUATION
IT WILL ONLY COST YOU THE PRICE OF A CAN OF SPRAY THROTTLE BODY CLEANER AND 20-30 MINUTES OF TIME IF I'M RIGHT!
THIS IS THE EXPERIENCE I HAD WITH MY WIFEY'S FORD ESCAPE....SEE MY ANSWER IN THIS LINK (AND THE LINKS WITHIN IT)
https://www.2carpros.com/questions/2005-ford-escape-every-day-crank-suv-high-idle-usually-after-30-minutes
YOURS LOOKS LIKE THIS
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_fuel-injection-idle-air-control-valve-delphi_25987774-p?searchTerm=iac
RETURN TO THIS POST (YOUR POST/ YOUR QUESTION) WITH A BIG OLE GRIN AND GIVE US SOME GOOD NEWS !!!!
THE MEDIC
May 28, 2013 at 5:54 AM
