i noticed that the idle is off once it warms up some. Also it vibrates the whole car while it is idling or at a stop. now it surges really bad under load especially at about 65 mph i can see the rpm's jumping around but it don't match up with the gas pedal. I have changed the mass air flow sensor and the throttle body and put new spark plugs and wires in it. The old spark plugs were so bad the electrodes were completely gone. I also changed the ECT sensor the MAP sensor and air filter. I checked the fuel pressure and it is about 60 psi.there is no check engine light on or no codes stored in the computer. I did notice that my fuel trims go negative when i am sitting in park or just stopped in gear.
Jun 10, 2019 at 6:51 AM
