The vehicle was parked, the following morning. It could not start but it is cranking. The fuel pump is functioning and supplying fuel, there is spark from the ignition coil. The fuses are intact. The timing belt was check, it didn't cut.
could you provide a diagram to check the timing belt if it has not jumped some teeth?
Aug 12, 2025 at 12:39 PM
