The actual problem was a broken bolt that holds the injector nozzle resulting in excessive diesel leakages. Fixing this problem involved dismantling the engine to access the bolt. The broken bolt was successfully removed and replaced. On completion of assembling back the engine, the engine could not, behaved as if the battery was flat. Tried to charge the battery but no change. What could be the probable problems and how can they be fixed?
Tried using a code reader to check for errors but nothing of much help, it was showing something to do with unbalance pressure within the injector nozzles.
Help please.
Help please.
Feb 23, 2017 at 3:30 AM
