Vehicle buck between thirty to forty kph
2010 HONDA STREAM
100,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JAGAS56561
  • 4 POSTS
The engine vibrates,and buck with a rattling sound between thirty to forty kph. it runs well above forty kph.
If the accelerator pedal is pressed the vehicle accelerates smoothly.
Jun 17, 2017 at 9:48 AM
I sounds like the spark plugs need to be replaced, here is a guide that will help you get the job done.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Please let us know what happens, we are interested to see what it is.
Jun 19, 2017 at 11:30 AM
JAGAS56561
  • 4 POSTS
Thanks for your response Ken. I have already changed the plugs and two ignition coils.
I am looking to check the idle speed control mechanism and if necessary the valve timing as soon as I get a chance. don't know if it makes any sense.
One love,
Mike
Jun 20, 2017 at 7:02 PM
I think is would be a good idea to run the codes to see what come up.
Here is a guide to help you get started.
Please run this test and get back to us so we can continue helping you.
Jun 21, 2017 at 11:17 AM
