Vehicle not communicating with Sealey ta 500 OBD tool.
2008 VAUXHALL MERIVA
52,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
MARNEMAINIA
Today I plugged my Sealey ta 500 scanner into the the car with the ignition on, but not running. The scanner lit straight up and said communicating please wait.Then after a while it says can not communicate check ignition is on or check connection.
The scanner is okay as I tested it on a Vauxhall Astra h and all okay.
Jan 13, 2017 at 8:00 AM
Hey MARNEMAINIA,
You need to turn the ignition off. Then plug the scanner in, then turn the ignition on.
Please let me know what happens so it will help others.
Best, Ken
Jan 18, 2017 at 1:31 AM
