ABS and 4WD lights on no start
2004 NISSAN ARMADA
203,000 MILES • V8 • 4WD • AUTOMATIC
KARI SCHIP
  • 6 POSTS
I have read and read and could not seem to find an actual solution.
Last night my VDC off, ABS, slip and 4WD lights came on. Pulled over at a gas station. Checked brake fluid it was fine. went to start my car and it will not turn over now. All of those lights are still on also. Any suggestions?
Feb 12, 2017 at 1:29 PM
HMAC300
  • 48,601 POSTS
scan for codes there is an /abs problem so it knocked all the other stuff off. check battery for condition including load test most places do for free.
Feb 12, 2017 at 2:10 PM
KARI SCHIP
  • 6 POSTS
Scan is showing no codes.
Feb 12, 2017 at 3:12 PM
HMAC300
  • 48,601 POSTS
if you used an auto parts scanner it will not pick up those codes only a professional model used by a mechanic will. Check battery though as it may be that auto parts and most other places do that for free.
Feb 12, 2017 at 3:25 PM
KARI SCHIP
  • 6 POSTS
Alright, I do not believe that to be it (it is trying to start like a champ), but I will for sure give that a try.
Feb 12, 2017 at 3:31 PM
HMAC300
  • 48,601 POSTS
have you tried a security system reset? see link.
https://www.2carpros.com/articles/how-to-reset-a-security-system
Feb 12, 2017 at 4:33 PM
KARI SCHIP
  • 6 POSTS
Just tried the security reset, not it either. Ughh
Feb 12, 2017 at 6:57 PM
KARI SCHIP
  • 6 POSTS
Took the battery into O'Reillys for a voltage test. Battery is good.
Feb 13, 2017 at 6:36 AM
HMAC300
  • 48,601 POSTS
if it still will not turn over and you hear a loud click have an assistant or you hit body of starter with a hammer if it starts the starter is bad that is if it will not turn over. if it turns over but does not run scan for codes or have a pro look at it.
Feb 13, 2017 at 6:50 AM
RENEE L
  • 1,260 POSTS
Hey KARI,
Here is a link to an informative article from this site with step by step instructions and pictures and a video on what to check for when your vehicle will not start.
If you need any further help please come back to the site as we are always happy to help.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Feb 13, 2017 at 7:22 PM
KARI SCHIP
  • 6 POSTS
Just an update. did a few of the recommended test. So far all check out fine. Replaced camshaft position sensor and crankshaft position sensor. It started, sputtered a little and died. Started it again, then died. Now it will not start again. Just cranks. All lights still on.
Feb 15, 2017 at 4:36 PM
HMAC300
  • 48,601 POSTS
because the battery was disconnected try the security thing again as that normally will apply the anti theft when the battery is disconnected. If not then check fuel pressure with a gauge auto parts rent it see link.
Feb 15, 2017 at 5:51 PM
