2000 Vauxhall Zafira BROKEN AIR CON PUMP
2000 VAUXHALL ZAFIRA
8,700 MILES • 4 CYL • 2WD • MANUAL
SVETRUCK
IS IT POSSIBLE TO BYPASS THE AIR CON PUMP WITH A SHORTER BELT
AS THE AIRCON PUMP BEARINGS ARE GONE AND GETS HOT SNAPPING THE DRIVE BELT
Jun 10, 2010 at 12:53 PM
DAVE H
  • 13,384 POSTS
you can bypass the A/C compressor if you find the correct size belt
Jun 13, 2010 at 3:48 AM
SVETRUCK
[quote:884e786a2e="Dave H"]you can bypass the A/C compressor if you find the correct size belt[/quote:884e786a2e]
Jun 13, 2010 at 1:16 PM
