2000 Vauxhall Zafira
2000 VAUXHALL ZAFIRA
TWINKLE4
I have a zafria that wont start. It has been in the garage , had the fuel pump off and tested,ok,filter and housing replaced,injector seals replaced,new glow plugs, pipes and joints replaced, filter in tank replaced and found oil in the fuel tank. After all this it runs for a few weeks and when you go to start again after overnight or a few hours, the engine turns over but no start. There is no fuel to the injectors. It feels as if the fuel drains back to the tank. Beginning to think there is a simple fault that escapes us. Where is the loss of pressure happening.
Any ideas please.
Thanks
Sep 15, 2008 at 2:02 PM
DAVE H
  • 13,384 POSTS
you will need to double check all the parts you replaced are sealed correctly .. it is looseing pressure somewhere ..
Feb 19, 2009 at 7:47 AM
