2005 Vauxhall Vectra FLICKERING HEADLIGHTS
2005 VAUXHALL VECTRA
70,000 MILES • 4 CYL • 2WD • MANUAL
DAVID ATKINSON
MY HEADLIGHTS REAR LIGHTS AND DASH LIGHTS FLICKER TO A POINT WHEN I THINK THEY WILL ALL GO OUT.WHILE DRIVING THE DASH LIGHTS STARTED TO GO OFF AND ON.RADIO WENT HAYWIRE.I REPLACED THE BATTERY AND ALTERNATOR ABOUT 2 MONTH AGO.GARAGE HAS CHECKED THE BATTERY AND TOLD ME IT IS CHARGING NORMAL.
Oct 30, 2009 at 6:00 AM
DAVE H
  • 13,384 POSTS
check the alternator and battery wiring .. you may have a loose connection/wire somewhere !!
Oct 30, 2009 at 6:51 PM
KEVIN_UK
David, Please see my post on flickering headlights. May or may not be related but worth checking out. If you move your steering wheel left/right and the lights flicker then it's probably be the power steering 'electric pump'. You can do this test while the car is stationary. Obviously, best carried out at night!
Nov 2, 2009 at 4:32 AM
