2002 Vauxhall Vectra whats wrong with my car
2002 VAUXHALL VECTRA
95,000 MILES • 4 CYL • FWD • MANUAL
BUNNYBASHER
my car engine is making a lot of noise with stalling problems when idle and in low revs the whole car shakes
Nov 4, 2008 at 8:20 AM
BABYGIRL616
[quote:50577e05a2="bunnybasher"]Noises problem
2002 Vauxhall Vectra 4 cyl Front Wheel Drive Manual 95000 miles
my car engine is making a lot of noise with stalling problems when idle and in low revs the whole car shakes[/quote:50577e05a2]
Have you got the problem sorted yet?
Does your have a timing chain? at the begining of the year my engine was noisy and felt like it had no power, i had the timing chain replaced as it was worn and jumped a tooth. There is a lot of improvement but the car is still not running at its best and has the same problem as yours. I have been again told the chain may not have been timed properly, but surely if this was the case the problem would be constant.
Nov 23, 2008 at 4:16 AM
BUNNYBASHER
[quote:02d13f3f75="babygirl616"][quote:02d13f3f75="bunnybasher"]Noises problem
my car engine is making a lot of noise with stalling problems when idle and in low revs the whole car shakes[/quote:02d13f3f75]
Does your have a timing chain? at the begining of the year my engine was noisy and felt like it had no power, i had the timing chain replaced as it was worn and jumped a tooth. There is a lot of improvement but the car is still not running at its best and has the same problem as yours. I have been again told the chain may not have been timed properly, but surely if this was the case the problem would be constant.[/quote:02d13f3f75]
funny enough had a mechanic look at it yesterday for me recons one of the injectors went causing the problems but now another has gone so the car wont even start will cost £40 to find out what injectors have gone and they cost about £40 -£50 each to replace plus mechanic charges
Nov 23, 2008 at 1:22 PM
