1.8ls engine stars from cold runs fine until reaching normal temp,cuts out and won't restart till fully cold,p1650 fault code no, fault light. fuel pump and temp sensor changed at garage no change in symptoms.have had suggestions, crank sensor or ecu. don't want to waste money on ecu as will cost as much as car worth.
Thanks in advance
Thanks in advance
May 25, 2010 at 2:06 PM
