2000 Vauxhall Vectra noisey hydraulic lifters
2000 VAUXHALL VECTRA
120,000 MILES • 4 CYL • FWD • AUTOMATIC
MWYSE
hello guys
2000 Vectra!
I have a vectra with a noisey lifter. My question is how do i tell which lifter it is? Do i have to remove the camshaft to replace a lifter? Could you suggest where to buy cheap parts for a vectra as i'm in australia and parts over here are very expensive.
And secondly i have a miss when at low idle. It's apparent that its an oil leak from the rocket cover gasket down to the spark plugs fowling the plugs causing the miss. I replaced the gasket twice but the oils still leaks. Could you make a suggestion on a better technique to fix the rocket cover gasket.
Also how do i adjust the idle, unlike the carby i am usless with fuel injection, but i think its a computer adjustment. Should there be another way i would love to hear.
Thanks for your time
May 22, 2009 at 6:44 AM
DAVE H
  • 13,384 POSTS
Yes you need to remove the camshaft to replace the lifters ... no timing adjustment is possible it is computer controlled .. use a good gasket sealent on a new gasket for the valve cover gasket !!
May 22, 2009 at 6:54 PM
