1998 Vauxhall Vectra Loss of power when accelerating
1998 VAUXHALL VECTRA
50,000 MILES • 4 CYL • 2WD • MANUAL
MATTROUTLEY
  • 12 POSTS
Hi guys,
I have a 1.6 16v vectra which runs like a dream first thing in the morning but as soon as the engine begins to warm up i lose power.
When i put my foot down to accelerate, the car sort of jumps as if fuel or air aren't getting into the mix properly. Thing is i've had friends say it could be fuel or air or exhaust gasses not escaping or problems with various sensors but i haven't a clue where to start!
I do get my ECU light coming on now and then but by the time i get it to the garage for a diagnostic, the light has gone out and the diagnosis comes up with no faults!
I would be really grateful for some help because i really like the car!
Many thanks,
Matt
Jan 21, 2009 at 12:31 PM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation ..much appreciated
You seem to have what's called an "intermitent" fault occuring .. unfortunately tracking it down is going to be the hard part .. it could be on any one of the sensors the car has .. usually when the MIL has been on, the car will store the code for a little while so next time it appears on .. take the car immediately to have it diagnosed ...this will be the easiest way of tracking it down ... from your description .. it could be an injector fault or even a spark fault/MassAirFlow/ThrottlePositionSensor etc. etc. .. it's really hard to diagnose without the code and we could be changeing parts without reason till we track the cause .. because you say it does not start till the vehicle gets warm .. I would first be looking at the coils or CKP(crankshaft Position Sensor) .. but as i said earlier .. without the fault code we are guessing and could replace these without reason ... if you can get the codes .. repost with them and we can diagnose the cure .. hope this helps in some way .. let me know !
Jan 21, 2009 at 5:41 PM
MATTROUTLEY
  • 12 POSTS
Hi dave,
Thanks for your response, you're right I am having real trouble diagnosing the fault.
It is almost like the fault codes are not being saved on the system. Do you know if there is anything that I can plug into my OBD whilst I'm driving that would pick up the fault as it occurs?
The reason I ask is because I have taken it to the garage 4 times now but the diagnostic never finds a fault!
Many thanks,
Matt
Jan 22, 2009 at 1:24 AM
DAVE H
  • 13,384 POSTS
Hello Matt.
You could buy an OBD handheld reader to plug into your car whilst driving around .. these machines are very good .. I own one myself and couldn't do without it nowadays .. unfortunately they are expensive in england ..(I'm presuming thats where your located) I bought my first one from the USA whilst i was still in england and believe me it was invaluable ... bear in mind the prices are in dollars so with the exchange rate it will be cheaper in pounds but you also have to take into account the shipping cost's ...you may also want to take into account the fact that the cheaper readers only give you the fault code then you have to research it's meaning .. if you go for a reader that will give you definitions it's a lot less hassle and it also keeps track of sensor working property's .. ie. it checks/monitors fuel trim and air ratio etc. etc. whilst your road testing .. it's worth the extra in the long run .. most garages charge at least fifty pounds to just diagnose a fault .. so you could actually make your money back just off friends and family and everybody who likes to do there own repairs will need one of these sooner or later so it will be a great help in the future..most DIY mechanics have there own reader here .. One more thing you need to take into account .. 1998 was the year vauxhall changed from OBDI to OBDII so we will need to see which type of DLConnector you have on your vehicle ? if your DLC (data link connector), which is usually located under the plastic cover under the handbrake on vauxhalls, looks like the diagram below .. the it's OBDII if it's more square looking it's OBDI ... let me know
https://www.2carpros.com/forum/automotive_pictures/266999_dtc_4.jpg
Jan 22, 2009 at 7:07 AM
MATTROUTLEY
  • 12 POSTS
Hi Dave,
I finally got around to checking my OBD and although it's not the exact shape you have drawn (it's more like a solid rectagle) it does have 16 points so am i right in assuming this is an OBDII port? if so i will by the expensive reader so i can hopefully get the problem fixed once and for all!
Regards,
Matt
Jan 27, 2009 at 4:21 PM
DAVE H
  • 13,384 POSTS
Yeah if it has 16 pins it is OBDII ... you will not regret the purchase .. it will come in handy for the future as well as now .. all cars are OBDII(can) (control area network) ..nowadays ..the one your thinking of buying should perform these checks ..let me know how you do ? .. if you need any help once you have the codes let me know .. Dave H PS. Just checking on a point ? .. if your DLConnector looks a bit like this it is OBDI .. let me know
https://www.2carpros.com/forum/automotive_pictures/266999_dlc_2.jpg
Jan 27, 2009 at 5:05 PM
MATTROUTLEY
  • 12 POSTS
Yes it looks exactly like the second diagram so I guess it's OBDI. Does this make things more awkward or are there other readers out there?
Matt
Jan 27, 2009 at 11:55 PM
DAVE H
  • 13,384 POSTS
Most good OBDII scanners will read your vehicle ... they just don't do everything on your actual vehicle they will do for the most modern vehicle's ... the problem with your vehicle is the connector .. vauxhall in their infinate wisdom decided to use a different connector from every other manufcturer, I guess so you had to buy from, or take the vehicle back to them, the law changed and every manufacturer had to us the same connector, but vauxhall didn't start putting the new connector on untill 1998 .. unfortunately you still have the old connector ? I had this trouble when i was an RAC/Greenflag Tech back in england, I had to buy a seperate connector just for vauxhall, as vauxhall wasn't released in the states, I never brought it with me and gave it to a friend, so you can get them, it's just a pain in the A***. ..lol.. let me look into a retailer for you .. I will get back to you a little later ..
Jan 28, 2009 at 5:58 AM
MATTROUTLEY
  • 12 POSTS
thanks Dave, it's really appreciated
Jan 28, 2009 at 4:00 PM
DAVE H
  • 13,384 POSTS
Just letting you know ! I haven't forgotten about you ... i'm struggling to find anyone who does the OBDI connector .. will get back to you ASAP
Jan 30, 2009 at 10:30 PM
MATTROUTLEY
  • 12 POSTS
thanks mate,
i just found site that says its compatible with a '97 vectra. do you think this would work?
www.myscantool.com
oh and i appreciate all this help and will donate some more to the site :)
Jan 31, 2009 at 1:47 AM
DAVE H
  • 13,384 POSTS
I could have sent you to hundreds of these sites .. our scan tools are exactly the same .. the problem is ALL vehicles made in the USA from 1996 had to be OBDII generic (they all had to be a standard across the board) which means that any garage/shop could read your cars computer for powertrain (emmissions/engine/gearbox) related issues .. It didn't have to go back to a dealer and garages/shops didn't have to shell out thousands of pounds/dollars on different diagnostic software for the different manufacturer's as we did pre 1996, (my first diagnostic laptop was the size of a suitcase and had 32 different connectors LOL)...unfortunately this did not follow suit in the UK/europe .. the standards did not HAVE to be brought in untill 2001 so although a lot of manufacturers started using the same protocols and OBDII link connecter around 1996 .. vauxhall did not, as they do not sell vehicles in the USA. now if you had a ford vehicle that reader would be great for you .. and it will probably read the PCM of your vauxhall .. it's just that the connector is different and in some cases the pin locations are different !! (each of the 16 pins on the connector has specific task)... so NO i'm afraid .. that reader will not PLUG into your vehicle and in most cases this is only because the PLUG is different !! .. vauxhall was bought out by GM(general motors) around 1997 which i think is why they started using the the NOW standard rounded 16 pin connector in 1998, plus they HAD to be ready (generic) by law by 2001 anyhow .. I'm sorry, i know this is frustrating but i've seen it time and time again people (vauxhall/citreon/renault owners)have bought readers because they say all vehicles from 1996 ..but that is vehicles sold in or for the USA market (ford/chrysler/honda etc.) only to find they will not work on their vehicle in the UK ..unless it was a vehicle that was also sold in the USA ...I'm waiting for a buddy of mine in england to get back to me .. unfortunately this will probably be after the weekend now (time difference work/family commitments etc.)!! could you supply the general area (ie. london/manchester) of where you live ??
Jan 31, 2009 at 6:19 AM
MATTROUTLEY
  • 12 POSTS
man it's a good job i didn't buy one of these months ago - i was very close to doing it!
i live in Bournemouth, in Dorset. Its on the south coast below London in case you weren't aware...
no worries about the wait, my wife bought a new car yesterday so she doesn't have to deal with the problem anymore. now it's up to me to fix it so i can use it for work - i do a lot of commuting!
Jan 31, 2009 at 6:44 AM
DAVE H
  • 13,384 POSTS
I know bournemouth .. we had a few training conferences there when i was an RAC tech !! i'm originally from manchester .. been living here since last year .. will let you know any info i acquire as soon as i can .. enjoy your weekend ... and have an english beer for me .. LOL
Jan 31, 2009 at 7:02 AM
DAVE H
  • 13,384 POSTS
I am still trying to find a connector for you !! .. nobody seems to have them anymore ... i've got my feelers out .. LOL .. in the meantime could you remove and clean or replace the MAF (mass airflow)sensor .. let me know ..
Feb 4, 2009 at 5:17 AM
MATTROUTLEY
  • 12 POSTS
hi Dave i hadn't realised that you posted this reply so i'll get on it this weekend, will try and replace it if possible and let you know what happens...
Feb 18, 2009 at 1:09 PM
DAVE H
  • 13,384 POSTS
Hey Matt
Thought you had forgot all about me .. lol .... the only place i can find still doing the 10 pin old vauxhall DLC is WWW.UKOBD.CO.UK .. there system is expensive .. but if you already have a laptop or use of one and you just purchase the connector i can set you up with some software .. or you could just enquire if they supply the handheld 10 pin aldl reader .. have a look and let me know what you think .. but still clean that MAF sensor !!
Feb 18, 2009 at 2:15 PM
MATTROUTLEY
  • 12 POSTS
Hi Dave,
That's awesome, i do have a laptop so do i buy the 10 pin connector (for £25), even though my connection does have 16 holes?
Would you be able to send me the right software? If so that would be so cool cos i can't really afford £340!!!
Thanks so much Dave
Matt
Feb 18, 2009 at 3:46 PM
DAVE H
  • 13,384 POSTS
Hey Matt.
I've sent these guys at ukobd an email double checking there selling the correct connector we need .. I should here something later today(your time zone) .. so hold off on buying till i get back to you ..if it's the right connector I can put you in touch with someone who supplies generic software (software for all vehicles not just vauxhall) which monitors all systems (fuel trim etc.) whilst road testing, this will cost around £50/60 on top of the connector, so it will cost you roughly what a handheld reader would cost ... the only difference is you will not be able to communicate with other systems on your vehicles .. ie. airbag,immoboliser etc. .. let me know what you think !
Feb 18, 2009 at 7:45 PM
MATTROUTLEY
  • 12 POSTS
That sounds great Dave, and a much more sensible price. This is really good timing because my other vectra that I use for work has done 150k miles and is on it's way out - head gasket is going!
Feb 19, 2009 at 12:10 AM
MATTROUTLEY
  • 12 POSTS
Hey Dave,
I don't know if you've heard anything back from ukobd but I emailed them too and they said the only thing that would work on my vectra is the vaux01 which is 340 pounds.
I know this is expensive but it would save me having to buy a new car if it helps me solve the problem.
I just had one more question (!) do you think this is a good bit of kit and would help me with diagnosing the fault? I don't want to pay all that money to find it doesn't help!
Thanks mate,
Matt
Feb 20, 2009 at 4:42 AM
DAVE H
  • 13,384 POSTS
Hey Matt.
Sorry didn't get back to you yesterday family/time zone etc. ..I got a reply off them late yesterday saying the same thing !! I have a real problem with their statement that your vehicle is not EOBD compliant .. my software alway's worked when i used the correct plug !! I'm tempted to say just buy the plug and this software www.gendan.co.uk/product_VAUXCHK.html ..and we could try this, to save you money ..but these guys at UKOBD make the plugs so it may only work with their software ? and I cannot find the plug anywhere else !! .. as for the software from UKOBD it sounds real good and if it does all it says it does (ie.) ABS/IMMO/EEPROM etc. I would be buying it if I was still in england .. my software subscription alone was £1000 per year for vaux/opel !! but of course I would easily make my money back as i work in the business .. If you are going to stick with vauxhall vehicles in the future this could also be invaluable to you if they are going to update software for free and it does say on the website regularly updated ...of course you could buy the software and advertise your services as a vauxhall diagnostic .. the immoboliser's on the vaux range are alway's going down in a carpark of asda .. LOL .. It really annoy's me that if you bought your car 6 month's later it would cost £60/70 .. to buy the tool ... So I'm jabbering .. lol ... your best option if you are going to stick with vauxhall cars is to buy this software with a gaurentee it will work on your vehicle or your money back ..you cannot go wrong if it work's especially in the future .. i'm loath to have you spend all this money knowing full well that any future cars you buy will be easily read by a cheaper bit of kit !!! the vauxcheck software is good i have used it ... but they are not offering the plug for your vehicle ..this is why i am saying the UKOBD plug may only work with their software ?? and UKOBD have been around for a few years .. I have bought off them before and alway's had good product's .. let me know what you decide .. !
Feb 20, 2009 at 5:48 AM
MATTROUTLEY
  • 12 POSTS
Hi Dave,
I have thought about it all and decided i'm just oing to stick the car on ebay!
It's not so important now that my wife has a new car and i'm just a bit fed up with trying to sort the thing out!
Thanks so much for all your advice, it has been invaluable and when my works car does break down i will make sure i buy a vectra that is '99 or later!
Vectra's are ideal cars for me because they're cheap to run and have a good bit of space for me to fit all my work tools in as well as my surfboard!
If i have any trouble with future cars i will certainly come to this site for advice!
Thanks again Dave, take it easy,
Matt
Feb 21, 2009 at 8:11 AM
DAVE H
  • 13,384 POSTS
Hey Matt.
I think you are making a wise decision .. it is a lot of money for a bit of kit you may never use again !! and as you say if you buy another vectra it will be newer, and you can get the same kit for £50 ...so it is worth the wait (hopefully you won't need it .. lol).. although I hate loose ends and would have loved to have got to the bottom of this .. lol ... (did you try cleaning the MAF ??) but hey this forum sets me a challenge everyday LOL .. Please spread the word of our forum to your friends and family .... hope you sell the car soon, and hopefully you will never need the forum again ... but we are here if you do !!
Happy Motoring ..
Dave H
Feb 21, 2009 at 2:58 PM
