This is a complex and time consuming repair if you have never done this before ? it means removing the timing belt and then re-setting up correctly afterwards ..which if not done correctly can damage the engine !! the vectra was not released in the USA so I do not have any diagrams or spec's to supply you .. your local library or autoparts store should be able to supply a repair manual for the vehicle with step by step instructions and diagrams of how to complete the repair .. get the manual and repost with any questions you may have during the repair and I will assist ....remember take your time ! it needs to be done correctly !!
Hope this helps
Mar 12, 2009 at 6:40 AM
