1995 Vauxhall Tigra Dash Lights
1995 VAUXHALL TIGRA
DAVIDS2934
Electrical problem
1995 Vauxhall Tigra Two Wheel Drive Manual 110000 miles
I have a problem with the lights on my dash, the lights for the heater switches, the temp gage do not work, and the central display with the time etc, the main screen is blank!
Does this sound like a major electrical problem or could there be an easy fix, fuses etc - sorry im not mechanical in any way!
Feb 17, 2009 at 4:20 AM
DAVE H
  • 13,384 POSTS
check the bulbs for the heater switch and temp gauge .. check the fuse for the centre display ..
Feb 17, 2009 at 5:15 AM
DAVIDS2934
Are the bulbs easy to check? - where do you have to remove the dash to access these?
Feb 17, 2009 at 5:27 AM
DAVE H
  • 13,384 POSTS
yes .. i'm afraid you have to remove the instrument cluster .. not the whole dash ... your local library should be able to supply a manual for the vehicle ..
Feb 17, 2009 at 5:38 AM
